Default Install PCI CAN
Hi all,
I'm writing because I want to change a value in the file to install my PCI-CAN
Indeed, by default port speed is set to 125 CAN baud, I need that it automatically adjusts 500baud ..
Do you have any idea what I could change so that this value set by default on 500 baud without my intervention ..
Can I change it in the install file? Or should I go through the windows registry via a script?
Thank you in advance for your help
(2,607 Views)
Which CAN device and API are you using?
I think Baud Rate is configurable in MAX.  If not, then you can use an XNET Interface Property node to set it prior to opening your session.  You shouldn't have to dig around in the registry.
(2,598 Views)
