Default Value
Hello...
         Can we change the default value of any control in run-time??
         Say, i'm having a numeric control,where the default value set as 103. Now in run time I will change it to 150 and next time when I run my VI the numeric control should have value 150,and not 103.
Thanking you,
sushmith
Thanking you,
Sushmith
Message 1 of 12
(5,621 Views)
No its not possible. You can set Default value only in edit mode.
Silver_Shaper | CLD
Message 2 of 12
(5,620 Views)
         Oh then it is a long procedure to change the value, we will have to store it in a file and reload everytime when i run my VI.
Thanking you,
sushmith
Thanking you,
Sushmith
Message 3 of 12
(5,618 Views)
Exactly..
Silver_Shaper | CLD
Message 4 of 12
(5,607 Views)
Why cant you use property node to change the value in run time. As soon as program loads pass the wanting value.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 5 of 12
(5,605 Views)
Read the question more carefully.  They want to retain a value between runs.  The OP asked if you could just change the default value in the run-time so that the value will be retained.  This can't happen.  You have to save the value to a file.  You can then use a property node or local variable to set the value after reading the value from the file.
Message 6 of 12
(5,577 Views)
Hello crossrulz,
           Yes, that is wat I wanted. I wanted to change DEFAULT value of a control during run-time. I wanted to know if any alternative method is there instead of saving it into a file and accessing it.
Thanking you,
Sushmith
Message 7 of 12
(5,556 Views)
Message 8 of 12
(5,514 Views)
Sir
--Ranjeet
Message 9 of 12
(5,497 Views)
You can do something like this to save & retrieve values without using a file.
Message 10 of 12
(5,480 Views)
