Defer Panel Update - Tree
I have a VI with a tree with several rows. I need to change the symbols for each row at any given time. The only way I know how to do this is to assign them one-by-one using a property node. This takes a while, so I would like to leverage the Defer Panel Update property so the tree isn't updated until all symbols have been assigned for all rows.
In the attached VI set the Defer Panel Update to TRUE, assign all my symbols and then set it to FALSE. This does not work as the tree is clearly updating when Defer Panel Update is set to true. Am I missing something?
(4,047 Views)
If you look inside that MGI function, you will see that it resets the deferral on each iteration
EDIT: My bad. I was thinking you had this in a loop.  Nevermind.
EDIT2: Yeah, so the MGI function sets deferral to false at the end, so when you change the symbols, Defer is False.
(4,039 Views)
The "defer..." invokes a GUI update ONCE when set to true and THEN the updates are defered until it is set false.
Could you share an image of your code since I do not have access to LabVIEW?
Ben
(4,015 Views)
Thank you you so much! This solves my problem.
(3,826 Views)
