Defuzzification of sigmoidal function
I'm working on a project and have to create a VI which does defuzzification of sigmoidal membership functions. I wish to use Centre of Area method. Can you suggest how i can go about the logic for designing the defuzzfication part for sigmoidal membership functions to obtain a crisp output?
I'm not using the fuzzy system designer but creating a VI based on the logic for defuzzification of sigmoidal membership functions.I have used 2 input variables and 1 output variable. I need help on how to go about designing the defuzzification part for the same,
(3,525 Views)
What have you tried so far?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,491 Views)
Thanks for your response.I have tried by directly using the defuzzification formula for Centre of Area method in a VI. But for some reason I'm unable to get the output which i had obtained by manual calculation. Is there an alternative method by which I can design the defuzzification part?
(3,472 Views)
You can always get 'inspired' by what you have in the LabVIEW source code... 🙂
C:\Program Files (x86)\National Instruments\LabVIEW 2014\vi.lib\addons\Fuzzy Logic\FL defuzzify output variables.vi
That will show you how we did in the Fuzzy Logic function, available in LabVIEW 2014.
Barp - Control, Simulation, RTT and HIL - National Instruments
(3,445 Views)
