Delay in Acquiring Signal (M series +SCXI modules)
My RT Data Acquisition System setup consist: PXI-8106  with three PXI-6254 modules(M-series), SCXI-1001 with four SCXI-1125 modules
Max Sampling Rate:10K
when I configure all the channels (count:64, both PXI and SCXI channels) and acquiring, I am observing a seven seconds delay of signal updating.
For example: 5V signal is applied, in software I can see that only after 7secs.
Note;For individual channel and few channels s/w updating has no problem.
As other DAS's are acquiring(updating) fine for the same signal.
->will this problem occurs with SCXI modules.
Please clarify my doubt
Thank you for any help in advance,
regards
srikanth.
(2,691 Views)
for the 7 sec's time... graph is showing old data. which should not happen.
ch. phani srikanth
(2,642 Views)
