Delay in labview
How to introduce delay in a while loop of LabVIEW?
Message 1 of 13
(37,003 Views)
Hi sukhiray,
you can use the "Wait" or "Wait Until next..." function. See also this link please. Smiley Wink
Mike
Message 2 of 13
(37,001 Views)
Message Edited by muks on 09-02-2008 03:28 AM
Message 3 of 13
(36,979 Views)
after using the while loop to a phase delay, I have no delay after the display of signals. I have use this code attached17487iF6E882DDFB6D753A
Message 4 of 13
(35,771 Views)
If you want to simulate a delay in the signal, you have to modify the signal. Your wait does nothing to change the t0 or append data to the front of the waveform. Not sure what exactly you want to do.
Message 5 of 13
(35,755 Views)
I really wante to make a late phase shifter for a pulse compressor. and for this  I have to delay several time a pulse, these signals that I obtain, I must submit them  to a treatment. the problem is that i don't know how to make a delay for this pulse.
thank you for your help.
Message 6 of 13
(35,745 Views)
to explain, I want to generate different  delayed signals from one square wave.
if you have any idea you can help me.
Message 7 of 13
(35,731 Views)
Message 8 of 13
(35,728 Views)
You want to delay a physical output after an acquisition? Then you would do something similar to your code except add the function that writes the pulse. If you use the Delay function, you will use the error in/error out connections to enforce dataflow. To simulate it, add another Square Waveform function. The while loop in your code does nothing so you can eliminate that.
Message 9 of 13
(35,727 Views)
Maybe this will help you. When you generate the square wave, you can add a phase to it.
17489i24F4E633FC230E22
Message 10 of 13
(35,718 Views)
