Delay in signals on graph using two different modules with NI cDAQ 9138
I'm using NI cDAQ 9138 to capture snapshots of various signals. I'm using a 9205 module to collect various low voltage signals and a 9225 to collect two high voltage signals. The problem is there seems to be a delay between the two sets of signals by the time they make it to my waveform chart in my VI. I've attached my VI below. I'm measuring current and voltage and they aren't lining up as they should. Any assistance would be great.
(3,525 Views)
are you using a Task created in MAX? can you provide a screenshot of how you have this configured if so? it seems this could be where the problem is.
(3,497 Views)
Yes I'm using a Task I created in MAX. I configured seven channels on the 9205 and then used the add channel option in MAX to add two high voltage channels on the 9225. I understand the 9225 has a different kind of clock, but I'm lost as how to make them both basically start at time zero.
(3,443 Views)
can you post screenshots of your tasks?
(3,416 Views)
Herre are acouple of screenshots.
(3,411 Views)
Here are a couple more.
(3,410 Views)
