Delay setpoint in PID
Hi everyone,
I am currently building an application to control a plant using PID on LabVIEW.
I would like to have the setpoint collected from an analog input module.
The problem is that I do not want the analog input signal data to be used as the actual setpoint, at the time its being read
What I want is to give a delay into the measured signal, so from that point on all data measured will be the set point, but with a constant delay.
Is that possible? Could you help me?
I really appreciate your attention.
Rafael
(3,319 Views)
I think i can solve it with the vi pt by pt queue...
(3,303 Views)
As far as I understood your problem, you do want to have the AI as the actual Setpoint. What you do not want is to have it as the current setpoint. Am I correct?
What do you exacly mean when you say "delay"? is it a time delay (i.e., 50 milliseconds) or you mean a discrete delay (I.e., using the AI value from the previous iteration as the setpoint for the current iteration of the loop?
Felipe Flores
Technical Support Engineer
(3,260 Views)
Hi Felipe,
Thanks for your attention.
In fact you understand my point pretty well.
I want a delay in time, which I expect to change for discrete since i can follow the iteration clock.
regards
(3,233 Views)
