Delay time
The attached code is ok. But I want to take data 1-hour interval. I tried to use the "time delay" option.
1. When I put it in no.1 place (red circle), data acquisition started 1hour later and then acquired data continuously.
2. In no. 2 places, It also started data acquisition after 1 hour, but after acquiring 1 time (1000 data), the code automatically stopped.
Would anyone please mention the proper place of using "Time delay" option or another way...? TIA.Capture.JPG
(2,843 Views)
Hi Milon,
As expected by THINK DATAFLOW!
Because of an error. Did you check the error?
Read data each second, but pick only each 3600th data…
(Of course inside the DAQ loop.)
No, it's not. Please read the style guide in the LabVIEW help!
(2,834 Views)
Accepted by topic author Chowdhury_Milon
if I understand your problem correct you can try this:
- Change "Continuous Samples" to "Finite Samples" and wire "Samples per channel" (e.g. with a constant of 1000)
- place "time delay" in the loop after "DAQmx Read", reading the same number of samples as configured for "sample clock"
UliB
(2,805 Views)
