Delete IP Camera from MAX?
I apologize in advance if this is posted in the wrong section.
I am using IMAQdx with the "IP Camera Adapter" mentioned in NI Document 60986GIJ.I was sucessfully able to stream to video from the camera. I am trying to delete the reference to that camera in MAX, but i cant.
I have also tried the following, deleting the file in C:\Documents and Settings\All Users\Shared Documents\National Instruments\NI-IMAQdx\Data, which reappears when MAX is restarted.
https://forums.ni.com/t5/Machine-Vision/How-to-remove-cam-from-quot-NI-IMAQdx-devices-quot-in-MAX/td...
(3,573 Views)
You might consider clearing your MAX configuration settings entirely if you aren't worried about losing other settings. You can find instructions here. Note that this procedure will clear ALL settings in NI Measurement and Automation Explorer (MAX). If this does not solve the problem or if this solution doesn't work for you, you should try posting your question on the Machine Vision forum here in case another user has experienced the same problem.
Andrew C.
(3,500 Views)
Hi Andy,
Thanks for the suggestion, unfortunately that too did not work. I will try the vision forum.
Thanks!
Andrew
(3,495 Views)
