Delete Progr Objects
Hi!
I would like to ask if it´s possible to create and also delete dynamically
front panel´s objects.Lets say for example that i want to create a button
with a code and afterwards to delete it.Is it possible ?
Thanks.
(2,924 Views)
Jior wrote in message <3977ffc7@newsgroups.ni.com>...
>Hi!
>Thanks.
You can use an attribute node to dynamically show/hide the front panel
control, or to disable it when not required.
(2,924 Views)
