Delete a channel or channel group in tdms file
Hello
I use Labview 8.2.
I want to delete a channel or a channel group in a tdms file. With the Storage VI, I can read the tdms file but the Delete Channel.vi don't work.
I insert my vi.
Thank you.
Rémi
(4,354 Views)
Can you attach you TDM file in order to use your LabVIEW application.
Regards.
(4,328 Views)
In the Zip file you can found a tdms file and a vi to visualize
Rémi
(4,316 Views)
Hello Rémi
It is not possible to delete anything out of a tdms file with the VIs from NI, neither channels nor groups nor properties. This is only possible with tdm files. You can create a new tdms file and copy the data you want to keep with the VIs I have posted to the thread http://forums.ni.com/ni/board/message?board.id=250&message.id=27470 and delete the old file after.
I hope this helps
Greetings
shb
(4,304 Views)
This answer is obsolete. There is now a TDMS Delete Data.vi
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/functions/tdms-d
_____________
Creator of the BundleMagic plugin for LabVIEW!
(775 Views)
