Delete an item from menu ring
Hi Veeru,
i not fully understand what you want! Do you want to delete the selected index? Say, if you select "0" you want to delete the first entry of the ring? At the moment you delete the element with the selected value!
Mike
Message 11 of 18
(961 Views)
Thanks Mike
I need to add few items to a control and delete the items as per the index number(selected).At the moment i can add and delete an item in separate programs,but when i implement both in the same vi the error occurs.
Message 12 of 18
(956 Views)
Hi Veeru,
see the attached example, maybe it helps.
Mike
Message 13 of 18
(945 Views)
Thanks Mike
I wonder what could be the reason that program gives error.
Message 14 of 18
(933 Views)
Veeru wrote:
Thanks Mike
Hi Veeru,
which one do you mean?
Mike
Message 15 of 18
(931 Views)
The vi i attached
Message 16 of 18
(929 Views)
Hi Veeru,
i think you have to write the new strings into the String[] property and into the StringAndValues[] property! Make sure to use each value only ones!
Mike
Message 17 of 18
(924 Views)
Thanks mike
Anyhow i am following ur ex vi.Thanks
Message 18 of 18
(922 Views)
