Delete duplicate entries
I have a 1D array of values, some are duplicates, which I need to delete as I only want one copy of each value.
Is there any quick function to do this?
Message 1 of 23
(7,294 Views)
Do you want to delete all duplicates or just duplicates that are ajacent to each other?
Message 2 of 23
(7,289 Views)
If you just want to delete adjacent duplicates here is a simple solution.
Message Edited by Tom Haggerty on 05-01-2007 07:30 AM
Message 3 of 23
(7,286 Views)
Unfortunately the entries are not nessisary next to each other.
Will your set up still work?
Message 4 of 23
(7,278 Views)
No, this is only for adjacent entries, but just a little more work and it will do the rest.  I just didn't know what you needed at the time!
Tom
Message 5 of 23
(7,276 Views)
This should work.  Maybe not the best implementation .... but it will work!
Message Edited by Tom Haggerty on 05-01-2007 08:10 AM
Message 6 of 23
(7,275 Views)
Thanks Tom, I'll give it a go!
Message 7 of 23
(7,267 Views)
This one also works and is maybe a little bit faster (delet from array is rather slow)..
/Sture
Message 8 of 23
(7,264 Views)
Sture,
If you inititalized an array before the loop, and did a replace array subset inside the loop and after the loop just grab the subset with values....
I believe your code would perform even better.
Ben
Message 9 of 23
(7,255 Views)
You mean like the attached picture ? I don't know how to make my pictures visible directly in the message...If I paste a picture inte the message nothing happens, is it a security setting I should change ?
/Sture
Message 10 of 23
(7,246 Views)
