Delete or Reset Shared Variables
Hello.
Anyone have a clever way of removing or resetting Shared Variables?  Every time I run my application it "appears" to be re-deploying the shared variables, but then I many of my controls are maintaining the value b4 the application was turned off.  I saw a bit saying you could use DSC to delete shared variables which I'd be okay with because then the application would just re-deploy the variables each time.  Cuz the code is set up for "First Time Runs" that's essentially being over powered by previous shared variables.
Thoughts, suggestions, white papers?
(3,739 Views)
Hi DailyDose,
It sounds like your shared variables are maintaining their values after you shut down your application - would it be worth having a re-initializing step that you use to set all the shared variables too whatever is appropriate to your application?
George B.
(3,693 Views)
