Delete or change Group name in TDMS file?
Is there a way to programatically delete or change a Group name in a TDMS file? The TDMS utilities seem much more limited in their ability than the TDM utilities to do functions like this - at least from what I can find.
George
(2,903 Views)
George,
There isn't currently a direct way to programmatically delete or change groups within a TDMS file.
What you can do however, is convert between TDMS and TDM using the VIs found in the Data Storage palette and then perform whatever modifications you need using the TDM utilities.
Hope this helps,
Simon H
Application Engineer
(2,889 Views)
