Delete or replace (NOT append) TDMS Channel data
Is there a way to delete channel data that has already been written to a TDMS file?
Just writting the new data tot channel data appears to append the new to the old.
I don't see a way of deleting OR replacing the old dat with the new.
Ben
Message 1 of 14
(11,439 Views)
There isn't a way. Options you have:
  1. Copy the data into a new file and leave out the channel to delete.
  2. Include a custom property for channels that indicates the "real" starting offset for channel data. Then to "delete" channel data, you set the real offset property to be the current channel length. Then when reading the channel, instead of starting at zero, you check the real offset property. Your files will be bloated, and may need a special reader function to distinguish the data, but it will work.
Jarrod S.
Message 2 of 14
(11,427 Views)
I know this is an older issue. Has this been changed in newer versions of Labview?
Message 3 of 14
(11,036 Views)
In LabVIEW 2010 look under File IO>>TDM Streaming>> Advanced TDMS.
This might contain what you are looking for.
Hope this helps.
Now Using LabVIEW 2019SP1 and TestStand 2019
Message 4 of 14
(11,028 Views)
Nope, still seems like there isn't a way to do it.
Message 5 of 14
(10,937 Views)
Accepted by topic author Ben
Hi markza,
Check out this example and see if it is what you need:
http://decibel.ni.com/content/docs/DOC-5735 (Delete single TDMS Channel from an existing TDMS File)
Have a great day,
Chris
Message 6 of 14
(10,925 Views)
Thank you Chris but...
You should go explain to Jarod why his solution count just went down by one. Smiley Wink
Ben
Message 7 of 14
(10,918 Views)
You know what's sad, Ben, is I was the one who wrote those TDM -> TDMS and TDMS -> TDM conversion VIs that the poster used in the example to delete a TDMS channel.
Jarrod S.
Message 8 of 14
(10,897 Views)
All is not lost.
Repost with a link to the same solution. That way I can mark your new reply so new users will find the example with a double bonus of you re-taking that solution and picking up some more Kudos along the way.
Go for it!
Ben
Message 9 of 14
(10,888 Views)
Can you upload detail explanations of new TDMS functions in LabVIEW 2011 or 2010?
I am considering the upgrade for TDMS function.
Labmaster
Message 10 of 14
(10,734 Views)
