Delete repeated rows from table
Hello, im having a trouble...
I have a 2D array (Table) as you may see in the image.
I want to delete all repeated rows except two, i want to leave one row with 123QSD and all the remaining columns and the 344MX and all the remaing columns.
Thanks!!
(3,414 Views)
Hi ethan85,
so you want to remove all the duplicate entries from the first coulmn, but you want to delete the complete row, right? In this case index the first column and search for duplicate entries and remove them, or you can also write the not duplicate entries into a new 2D array.
Hope it helps.
Mike
(3,394 Views)
See here for examples. You might also be interested in the Remove Duplicates from 1D Array.vi from the OpenG array library.
(3,380 Views)
Thanks JB one of the examples worked!
(3,369 Views)
