Delete some clusters from an array
I have an array of clusters which are composed by two real numbers, during my algorithm sometime happens that that the two numbers are marked as NaN, I want to remove those clusters from the array, how can I do?
Thank you
(3,781 Views)
(3,776 Views)
Since LabVIEW is an ever-evolving Platform, it helps us (to help you) to provide a little more information about your situation.  We always ask for code attachment (since, among other things, we can determine what version of LabVIEW you are using so we don't give you a LabVIEW 2016 "answer" if you are using LabVIEW 7.0), and even in a generic question such as yours, knowing the LabVIEW Version would enable us to suggest (or not) using a Conditional Array Indexing tunnel as part of the solution ... [that's a potential hint, by the way].
Bob Schor
(3,716 Views)
At the end I managed to do it, thank you anyway 😉
(3,681 Views)
