DeleteGraphPlot
I have question even if i feel that's a  stupid question but i have doubts about the function DeleteGraphPlot()
When we use this function all the data entered in plot functions (plotXY, plotY,...) are deleted ???
means  when i use DeleteGraphPlot the graph and the data also  are deleted from the Graph control ???
means the graph return to the initial state ?????
(3,741 Views)
?? What is DeleteGraphPlot??  I don't know this function, and it doesn't show up in QuickDrop.
BS
(3,711 Views)
FENM,
Are you using LabVIEW or a text based language? If you are using CVI or Measurement Studio it would probably be best to ask this question in the related forum.
If you are actually using LabVIEW, can you attach the VI you are using? I am not familiar with the DeleteGraphPlot function (is it a property or method?) but I might be able to help out if I see where you found that function.
(3,691 Views)
Thx Jacobson And Bob_Schor for your response  , i will post this question in the forum of Labwindows CVI
(3,667 Views)
