Demonstrate use of Zscale.lowcolor and Zscale.highcolor
Can someone please post a simple example demonstrating use of these property nodes of intensity graph.
Don
(2,720 Views)
The high and low color is applied to areas the are above or below the range of the current z axis. The attached example has data for +/- 120, but the z axis is only +/- 100, thus you get areas shown in the hight or low color. Of course this only makes sense if the z axis is not set to autoscale. 😉
Message Edited by altenbach on 02-08-2007 03:19 PM
(2,719 Views)
Thanks Christian:
I think my confusion had to do with exactly what you stated - you must turn off z axis autoscale.
I can think of some good uses for this -  a long time ago I wrote a VI to remove outlier points in 2d arrays/intensity graphs and color code them.  This looks like it can be an easier and faster way to do the same thing.
Sincerely,
Don
Message Edited by DonRoth on 02-12-2007 07:49 AM
(2,698 Views)
