Dependancy issues
Hello ,
I am using the ULx For labview for talking to measurement computing DAQ  USB-1408FS. The issue I am having is attached.
It is looking for a specific path which I do not have , I am using labview 2017.
Please can someone guide me how to fix this issue.
Manreet
(4,311 Views)
Accepted by topic author Manreet
These are warnings, not errors.  The file is being opened for the first time in 2017 (previously 8.5) and the paths are different.  If you save the VI with the new dependency path, these warnings will not appear again.  Make sure you have a backup copy before saving to a new version.
aputman
(4,299 Views)
Did you install the Measurement Computing drivers that came with your USB-1408FS?
Have you ran the required InstaCal from Measurement Computing?
https://www.mccdaq.com/daq-software/instacal.aspx
Omar
(4,292 Views)
each time I open the VI this warning appears . Here are the steps I took
when I opened the VI , this warning box showed up, I hit ignore and then from File , I hit save but that did not work.
What am I missing here ?
(4,288 Views)
yes I did install the instacal that came with the DAQ and have the device configured as well , my code works but this warning shows up every time I open the VI
(4,287 Views)
Thank you for your help , I was not accepting the save all when I was trying to close the vi , when I did that it worked !
Thank you for your prompt response !
(4,267 Views)
