Dependencies file does not exist warning
Hi all, i am getting an error when creating a new project.  After adding my file, i right click and refresh dependencies.  LabVIEW cannot find the file WDT Get Waveform Subset.vi from the NI waveform vi.lib.
I can open my file with no errors as normal.
Have deleted the waveform folder from the vi.lib and repaired with LabVIEW 8.2 but still has same error.  When i ignore item, the file has a warning stating "file does not exist in the dependencies list.
Anyone else seen this problem?
Best Regards,
Grant
(2,830 Views)
Hi Grant,
This is a strange problem most likley down to some linking errors within the project. I would recomend mass compiling the waveform directory and deleting and replacing the WDT Get Waveform Subset.vi from any VI's that use it in your project.
Regards
Jon B
NIUK & Ireland
(2,800 Views)
