Deploy Update Vi express
I created several express Vi to control devices on a bench test.
These express Vi allow to easy program the device. ( power supply, oscilloscope, generator .... )
When i modify the source code or the config code of the express vi, the modification is not deployed in my Labview program.
My Labview program keep the previous version of the express VI.
The Express Vi has not the same behavior as Sub Vi.
Where is the cache where is located the vi express used in my labiew program ?
I have to replace the old vi express by the new manually.
Thank you for your help !
(3,021 Views)
So learn how to do it with "real" instead of "Express" VIs.  If you want to do something once, with maximal hand-holding, use Express VIs.  If you want to do something programmatically and with variable parameters, you will probably do better with the actual LabVIEW functions that make up the Express VI.
Bob Schor
(2,974 Views)
