Deploy startup DLL using ".CDF" files
I'm new on Labview and I would like to deploy startup DLL on a PXI target using ".CDF" files.
I've already read this tutorial : https://www.ni.com/en/support/documentation/supplemental/11/using-application-components-to-deploy-l...
But there is no mention of deploying DLL.
As you can see on the screenshot below i've included the *.DLL file in the sources files.
When I build the application, I can see that the path of my dll has been added to appbuilder.cdf :
"<CODEBASE FILENAME="ni-rt/startup/XXXXX.dll" TARGET="/ni-rt/startup/XXXXX.dll"/>"
But after the deployment, the target doesn't launch the DLL anyway.
Finnally when i manually add the path of my DLL to the key StartupDLLs in th ni-rt.ini and then reboot my target, it works fine.
But the idea is to do it automatically using ".CDF" files.
Thanks for your help.
(2,790 Views)
Accepted by topic author Pierro26
Problem solved.
I just paste the path to my DLL in my ".CDF" file between :
<MERGEINI TARGET="/ni-rt.ini">[LVRT]
StartupDLLs=c:/ni-rt/cvi/My_DLL.dll
</MERGEINI>
It seems that FTP my DLL inside the "CVI" folder helped.
To do that i changed the "Support folder" value from "/ni-rt/startup/data" to "c:\ni-rt\cvi"  in My Real-Time Application properties, section "Destination".
(2,759 Views)
