Deploy using SCCM standard method of using System Account User
When running a silent deployment using SCCM, I get this error:
Fatal Error!! Required MSI directory property PersonalFolder is in an invalid location "C:\WINDOWS\system32\config\systemprofile\Documents\".
Once I click “OK” the installation continues and appears to install successfully.
We can’t have an error pop up message happen during the installation since that will be hidden and cause a stop of the deployment, or it would require a user to be logged in and click the “OK” button to continue the installation.
What do I need to change in order to accomplish a standard silent SCCM installation using the default system account user?
Installing under the user context is not an option for us.
Also...I don't see anything being installed to the user's "Documents" folder when installed manually under the user context.  Why is this folder being referenced and causing an error if it is not used?
I am attempting to deploy LabView 8.5.1 (8.5.306)
(6,394 Views)
Check out this KnowledgeBase article.
http://digital.ni.com/public.nsf/allkb/27EA40DBE745BDBD86257133007CE31A
Jason H
Automated Test Software R&D
(6,358 Views)
Thanks, but the System Account user does not have a Documents folder at all.
From what I can tell from an install done manually, the documents folder is not being used to install anything into, it is just being "looked up".
My client want us to deploy this software using SCCM, which deploys using the System context.  Any files needed per-user would then be repaired using either Active setup or advertised shortcuts.  This is standard MSI methodology.
So I need to know if there is another parameter or silent.txt file that I can use that will have the setup either ignore the error, or map to a different folder.
(6,353 Views)
What operating system are you trying to deploy the LabVIEW 8.5 applications onto?
Jason H
(6,345 Views)
Windows 7 32 bit and 64 bit.
Using SCCM 2007
(6,340 Views)
LabVIEW 8.5 is not compatible with Win7.  Doesn't mean it can't work, but no guarantees.
https://www.ni.com/en/support/documentation/compatibility/17/labview-and-microsoft-windows-compatibi...
(6,334 Views)
This regards LabView 2016 too. You cant use SCCM to deploy this software as it is deploying as per "SYSTEM". Meaning no document-folders.
Our environment is non-admin users.
This means LabView cant be used with SCCM to deploy? Or does NI have another solution?
(5,639 Views)
