Deploying Shared Variable library error -2147220735
I had to reinstall my whole LabVIEW installation, as my SSD was getting to full. I uninstalled everything and installed freshly everything on a larger hard drive. Unfortunately, I'm now getting an error and wonder what I have to reinstall.
When I want to deploy a Shared Variable Library in LabVIEW 2014 32-bit, it returns with an error:
Initializing...
Calculating dependencies...
Checking items for conflicts. This operation could take a while...
Preparing items for download. This operation could take a while...
Deploying My Computer
Deploying test.lvlib\\10.0.10.45\test deployment failed (error: -2147220735, MAX: (Hex 0x80040301) Internal error: The specified class could not be found in the configuration database. Your installation may need to be repaired.).
Deployment completed with errors
Any suggestions?
Message 1 of 8
(8,309 Views)
You are trying to deploy to 10.0.10.45, whatever that is.  If you open the NI Distributed System Manager, can you see this target?  If you open the target, can you see deployed variables?
I'm forgetting who "manages" the Shared Variable Engine, and what is needed to be sure it is installed.  You should be able to find some Help on this by looking up Shared Variable and/or Shared Variable Engine.
Bob Schor
Message 2 of 8
(8,289 Views)
Install Network Variable Engine or at least Variable client support if you want to host the variables on the host computer.
http://digital.ni.com/public.nsf/allkb/107EEBF71ECA3683862572B1007B00E9?OpenDocument
Best regards
JM, LabVIEW CLA
Message 3 of 8
(8,267 Views)
@Bob_Schor, the address is my local IP address. I'm trying to deploy it locally for testing. Actually the interesting thing is that when I want to create a new process in the NI Distributed System Manager, I get the same error.
@JonasM, that link is regarding an RT target, my problem is with a normal Windows 7 machine.
Last week I performed a repair of all my NI software. Under the Configuration Panel / Programs and Features / National Instruments Software, I selected everything and selected Repair. It took a full day to do it, but in the end it didn't solve it ...
Interestingly the Variable Engine seems to be installed in Windows and the service is running:
Message 4 of 8
(8,229 Views)
Accepted by topic author Harlequinade
You tried a repair, that sometimes works but sometimes a fully uninstall and reinstall is needed. Did you try to repair only the file suggested in below KB?
http://digital.ni.com/public.nsf/allkb/67E896D850D988C286257811005FEFF5?OpenDocument
As you see the same error in distributed system manager the fastest solution would probably be to uninstall LV and drivers and just reinstall them. If the above KB doesn't work.
Best regards
JM, LabVIEW CLA
Message 5 of 8
(8,216 Views)
Reinstalling that specific component by that installer did the trick. Thanks for the tip!
Message 6 of 8
(8,187 Views)
Hi, the posted link is not accesible anymore, i have the same problem using OPC and shared variables and the last resort i have is reinstalling all the application, please, do you remember what that domcument said or how to solve it?
Thanks in advance
Message 7 of 8
(1,975 Views)
Sadly, you are asking 10 years after the last post.  Maybe you should start a fresh post, provide as much information as you can, attach as many code files as we need to see (but make sure that most of us can read them, so use "Save for Previous" and specify LabVIEW 2019 or 2021).
Message 8 of 8
(1,937 Views)
