Deploying an application that uses Switch Executive VIs
Have successfully built an application installer using the Application Builder, but when I go to run the application from the Start menu (after its installed successfully) it asks me to register NI Switch Executive.  Obviously, my application uses Switch Executive VIs and earlier on my installer required nise.dll and niselm.dll - which I included.  How can I go about deploying this app on another machine w/ the 2010 runtime if I use Switch Executive VIs??
(2,583 Views)
Hi taft,
You might want to check out the document found here: http://digital.ni.com/public.nsf/allkb/836390E0A691E1B786256DDD00780A85?OpenDocument (How Do I Deploy My Switch Executive Configuration to Target Systems?)
Additionally, you may need a deployment license. For further information on that try looking here: http://ae.natinst.com/public.nsf/web/searchinternal/94c055996f4bae2e862574b40054132a (Differences Between a NI Switch Executive Deployment License and Engine)
I hope that helps!
-Matt
Matt
NI Community Team
(2,559 Views)
