Deploying an application using a component definition file is not working(cRIO 9035 - LV2015)
I created a stand alone real-time application for cRIO 9035 with component definition file but when I try to deploy with MAX, I cannot see the application - MAX has the standard add/remove software dialog. The files are created in "National Instruments\RT Images\User Components" folder.
I was able to do it with cRIO 9068 in the past without any issues. Do you know what am I missing?
I want to sent the build files to a colleague from another location so he can deploy to a similar system without me having to create a big image file with RAD for every small change in the code.
Thank you!
Lucian
CLA
Message 1 of 8
(6,136 Views)
Accepted by topic author LucianM
Hello Lucian,
What you describe is actually a known issue with the cRIO-903x family. The is already a CAR about it so even when I won't be able to give you a time frame for a solution, it is already being addressed by R&D. The CAR number is 545686, so if you see a bug fix with that number in a future software release, it will mean it was fixed.
Unfortunately, right now there is no workaround identified, so the only way to get the application running on any cRIO-903x is either pushing it through a project, or deploying an image (which is what we are trying to avoid with the component definition).
Camilo V.
Message 2 of 8
(6,108 Views)
Thanks @Cavarval for the quick response. We hope the fix will come soon..
Lucian
Lucian
CLA
Message 3 of 8
(6,089 Views)
Hello Lucian,
Glad to help.
Camilo V.
Message 4 of 8
(6,063 Views)
We have had similar issues when working with Linux RT based targets.
I believe the issue was caused because the component definition file was generated for pharlap based systems.
We currently solve the issue by manually changing the .cdf file so that it can be used to deploy to Linux RT based Targets.
<OS VALUE = "NI-Linux x64">
All Target paths should be updated to be relative to the Home Path
Any DLL's that are referenced should be removed, or replaced by the required .so files
and at the bottom of the file, you'll have to change the path style of the startup location to comply with Linux Path styles.
I'm currently working on a tool to automate this process, and execute this as a post build step.
But I hope NI will fix the issue in the near future 🙂
Message 5 of 8
(5,868 Views)
Hi Jorn,
DId you ever create an automated way to modify the .cdf file for linux RT targets? We have currently run into exactly the same issue and I am having trouble modifying the file to make it work.
Regards
Jon
Jon Bowers
LabVIEW Architect, TestStand Architect
Message 6 of 8
(5,727 Views)
Hi Jon,
We've made a small VI that modifies the CDF file as part of a post build process.
I've attached the VI (LV 2014 SP1)
It won't win a beauty contest, but it works for us.
There might be some more adaptations necessary depending on your application, if so, just give me a message and i'll see what i can do.
Message 7 of 8
(5,713 Views)
Hi Jorn,
Thanks for such a quick response! I modified the file with your VI and I can now install my application via the system config API.
Thanks for the help thats really saved me some trouble.
Regards
Jon
Jon Bowers
Message 8 of 8
(5,686 Views)
