Deploying my LabVIEW installer with new build of labview to 10 machines in powershell
I have a labview project that has two separate LabVIEW vi's. One of the VI's is the main gui and the other is a VI that then runs some third party executables. Therefore I then make an installer by right clicking on the Build specifications > New > Installer to make my installer. I then build the entire project and right click on the item that has the pc with a disk named installer.
I have upgraded to LabVIEW 2022 Q3 and I need to update like 30 machines. I don't want to go to each machine and have to click on ALL the accepts terms and conditions. This takes far to long. Does anyone know how I can run the installation silently in the background on LabVIEW 2022?
Do I have to use a different build process? By picking something else from the list?
Has anyone found a solution to a similar problem?
(2,367 Views)
Hi  luismoralesphysics,
As I understand from your post these computers are connected via internal network.
I suggest you to write a script that will automatically install it.
(2,326 Views)
Your installer package has an associated ini file. I would suggest messing around with the ones and zeros until  you get the behaviour you desire.
The second part of actually executing the install package will require a remote script as Anasei suggested.
Former Certified LabVIEW Developer (CLD)
(2,311 Views)
Create Silent Installer for LabVIEW Executable and LabVIEW Run-Time Engine
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YIUlCAO&l=en-US
(2,281 Views)
