Deployment / Run at Start Doesn't work
Having an odd issue here now that the RT SW we've written runs absolutely fine (i.e. Right click run on the main vi or via the LV GUI) and builds without error but does not run when deployed nor does it start when you've set "Run at Startup".
No errors popping up anywhere.
How can I diagnose this?
Thanks!
(803 Views)
Try the steps in Startup Executable Does Not Launch on Real-Time (RT) Target
https://tmesystems.net/
(763 Views)
When trying to open the error log in MAX from the PXI RT I get this, even after a reboot:
However getting the logs manually doesn't show anything obvious other than:
2024-05-07T13:00:02.441+00:00 NI-PXIe-8861-xxxx kernel: [ 27.220475] process 'local/natinst/labview/lvrt' started with executable stack
When I deploy the code...
(754 Views)
