02-18-2019 08:44 AM
I am trying to build a set of VIs that will be loaded dynamically by a built LabVIEW app (.exe)
I'm using a 'Source Distribution' type build spec. One of the VI's to be loaded dynamically calls a malleable subVI which in turn calls another (ordinary) subVI. That bottom-level subVI doesn't get copied by the builder (breaking the callers). The malleable VI seems to be embedded in the built 'top-level' VI, it is not saved as a separate file; and when I open it (in the IDE), LabVIEW displays:
Apparently the Source Distribution builder gets confused by malleable VIs. Is there a known workaround for this?
Solved! Go to Solution.
02-18-2019 09:26 AM
I found the solution:
Build Spec -> Additional Exclusions -> Disconnect unused inline subVIs
must be unchecked.
02-18-2019 10:59 AM
Well, that worked for a while. But now it's doing the same thing again.
