Description of Project labels in SCC system
1. How can I add a description to label of Project in the Source Code Control system? (I want to describe the changes that I made in a project).
2. It is possible to group the labels in the system, according to the projects? (I can see only a list of labels of all the projects).
Thanks.
(2,502 Views)
You can add comments to a VI that you are checking in. This is done under SCC Check Files In >> File Properties >> SCC Edit Change Comments. If you want to see all comments go to SCC Advanced >> Select your project >> Select a VI >> File History. You can add a label to a version of a VI from the SCC View File History window. Click the 'Label Current....' button and add a descriptive 8 character name.
2. You can create a 'Project Group' for projects that you want grouped together. I cannot see a way to group specific files together based on a their labels.
Chris_Mitchell
Product Development Engineer
Certified LabVIEW Architect
(2,502 Views)
