Design 1313 with our own function
We are planning to design our own Terminal block for SCXI-1125 with attenuator and with AC coupling circuit
(both selectable). How can we get information to design this block?
OR can any one send how SCXI-1313 works when you want to select the attenuator on/off automatically
when a high range is selected?
Rg
Naushica
(2,894 Views)
Hi Naushica
Unfortunately circuit sheets are not made available by National Instruments and therefore you will be unable to get information on how to design your custom terminal block. However there are custom kits available and you can view more information at this link:
https://www.ni.com/docs/en-US/bundle/371063a/resource/371063a.pdf
Hope you will find this useful
Kind Regards
YatinM
(2,868 Views)
