Design and build vi's
Hi Guys,
Sorry if this has been covered before! As I am new to Labview and am finding it a bit difficult:mansad: my question is this, I need to design a Vi that will identify transitions between high,low and calculate the number of logic 1s as a percentage of total number of samples, which is up to 100. Can any one help get me started with a few pointers or suggestions on how to build this.
Thanks in advance Smiley Happy
Spoiler
Message 1 of 15
(3,822 Views)
BUMP still need some help please:)
Message 2 of 15
(3,791 Views)
From where these transitions are coming
User generated or you are getting it from some device.
Have you tried somthing or learnt state machine ( your question is not very clear but for almost anything state machines are good solution )
Message 3 of 15
(3,789 Views)
Hi Neos,
Thank you for your reply. this is an assighment, that i have been given by my university. The assignment would like me to design a vi that will take a TTL square wave of 100 samples, stored in an array.  from this the vi should be able to identify all the high and low logics and display them as a percentage of the 100 samples?
Message 4 of 15
(3,783 Views)
Have you done any part like how you will store the values in array.
Any attempt or something????
Message 5 of 15
(3,779 Views)
No not yet, as I am new to to LabView and am looking around for ideas or pointers! The array will just have numbers from 5 +- 0.5v logic high and 0 +- 0.5 v logic low
Message 6 of 15
(3,774 Views)
Hopefully you are not lookin for solution stright awaySmiley Happy
because its your homework so better you do it and enjoy.
To start with i am showing you a very rough situation
suppose you have an array. you want to know that how many elements in this array is greater than a certain threshold and what is the overall percentage of such elements to original elements.percentage.png
This image is totally intended for how you can do things in LabVIEW.
Message 7 of 15
(3,768 Views)
Thanks Neos,
That's very kind of youSmiley Happy Il have a play with it on Monday when I'm back at uni. Would you be able to give me a breath description of how it works?
Message 8 of 15
(3,752 Views)
Hi neos,
Im having trouble locating some of the parts your using in you VI. Can you tell me what the part on the left is called numbered 1 to 4 or a breath description.
Kind regards.
Message 9 of 15
(3,711 Views)
@REXMAN wrote:
Hi neos,
Kind regards.
That's an array constant. You'll probably want an array control instead.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 10 of 15
(3,709 Views)
