Design in Labview that will input a decimal number from 0 to 15 and convert it into a 4-bit binary
hey, im new in labview so , how to Design in Labview that will input a decimal number from 0 to 15 and convert it into a 4-bit binary number and the Whole VI should be controlled by a stop button.
If the user given number is out of range then error message should be displayed.
Binary number should be displayed in form of LEDs.
(710 Views)
Hi nxysi,
So you need:
  • a while loop
  • a stop button
  • an integer (!) control (maybe with limited input range!?)
  • a simple function from boolean palette
  • an array (!) of LED indicators
What have you tried so far and where are you stuck?
We generally tend to NOT solve your homework…
  • don't forget the wait function inside the loop (!)
(687 Views)
