Destroy rendezvous
I'm using rendezvous to run several vi's at the same time but when I exit out, I want the program to exit LabVIEW.
Right now, the program stops when rendezvous is closed. If I exit LabVIEW before closing rendezvous, it gives me an warning message.
Is there a way to exit LabVIEW and close the rendezvous?
(2,984 Views)
Hello tgif,
Are you looking to exit LabVIEW from the one of the subVI or the main (calling) VI?
You can refer to the the shipping example "Rendezvous with SubVIs" to see an example on how this concept can be used. Also if you can attach a sample VI that states yous issue then it would be much easier to understand your helpful.
Chetan K
AE-NIC
(2,956 Views)
