Detailed Help Loads Slowly
I recently started at a new company and was able to set myself up with LabVIEW with their enterprise license.
I've been struggling with an issue though: Via Context Help, clicking on Detailed Help freezes LabVIEW
 (with a loading mouse indicator) for ~45 seconds until it loads the topic in the NI Offline Help Viewer. With the Viewer open, clicking another topic results in another ~45 second freeze and load.
Is LabVIEW trying to reach an -Online- help before failing over to an Offline Help Viewer, or is everyone directed to the Offline Help Viewer outright.
Anyone have any ideas?
(2,657 Views)
Maybe!  I think there is an ini setting that tells LV not to try online help, but I forget what it is.
Bill
CLD
(Mid-Level minion.)
(2,631 Views)
Accepted by topic author arccosined
What version of LabVIEW is this?  Is it 2022 or newer?  I think that's when online help started.
You can try turning it off by following these instructions.
  1. From the Windows start menu, navigate to National Instruments » NI Help Preferences.
  2. In the NI Help Preferences window, disable Use online help.
  3. Click Apply.
Copied from this page:
https://www.ni.com/docs/en-US/bundle/flexlogger/page/changing-ni-help-preferences.html
Even on older versions I do find that the local help would take a while to load the first time I clicked it for anything though...
(2,616 Views)
Thank you Kyle97330!
This was exactly what I needed. Offline help loads right away and should be fine for my needs.
Thanks for everyone's help.
(2,590 Views)
