Details on use of Device Control/Status.vi
Hi:
I would like to use the Device Status/Control.vi to check the status of the CTS and DCD lines on a serial port.
How to do this?
Brooke Clarke
brooke@pacific.net
(2,731 Views)
I never used this VI but I did use VISA to do it. Get a Property Node on the VISA palette, right click on it and select Properties>Modem Line Settings. Others may disagree but I always prefered using VISA over the older serial drivers and in fact the old ones are no longer supported by NI or included with LabVIEW.
(2,731 Views)
Dennis is right--you should use VISA.
The Device Control/Status function does not do what you want it to do.
Brian
(2,731 Views)
