Detect data type within Variant
I typically flatten the variant to xml using the aptly named Flatten to XML function.
Message 11 of 20
(4,439 Views)
Well since you really want to walk THAT path...
JPD developed code that is now part of Open_G that parses variants.
You could either use his coe or look at what he is doing and apply it to your situation.
Ben
Message 12 of 20
(4,432 Views)
You may want to take a look at the Read/Write Anything VIs from Moore Good Ideas.  They can take any cluster and write it to an INI file.  The code is mostly unlocked so you could probably modify it to write to any other format you need.
Message 13 of 20
(4,423 Views)
Yes that is another good example to harvest.
My nugget on control refs may be of some use.
But building off what Dave showed us...
restrcture the clusters as string (or enum) and a variant. That way all of the cluster will be converted the same way. Pull the variant from that conversion to a sub-VI that coresponds with the cluster type (driven by the string or the enum) and inside the appropriae sub-VI convert the sub-varian to the proper cluster type.
Ben
Message 14 of 20
(4,417 Views)
Perhaps you could use something like this.
Message 15 of 20
(4,414 Views)
Take a look at the OpenG Variant Configuration File Library .  In particular Write Section Cluster      It does something very similar to what you need and should be easy to modify.
Message 16 of 20
(4,382 Views)
Wow, thanks to everyone!  This is very helpful and I will start working through your suggestions.
Erik
Message 17 of 20
(4,377 Views)
In the end of it all, I still believe the LVOOP approach is elegant, easy to maintain and robust.
negative:
Learning curve.
Ben
Message 18 of 20
(4,373 Views)
[Wayne C writes: "Take a look at the OpenG Variant Configuration File Library .  In particular Write Section Cluster      It does something very similar to what you need and should be easy to modify"]
I was curious about your proposed solution... I put together something really fast just to see if it would work... and it did! disclaimer: it might not be the most elegant solution
See attachment -compiled in LabVIEW 2015-
Message 19 of 20
(3,504 Views)
You also might consider upgrading to LabVIEW 2015
I have not looked into these functions myself but.....I have a bit of faith
4 years of NI R&D efforts since the last post might have obsoleted your efforts
Message 20 of 20
(3,479 Views)
