Detect numeric change from a indicator
HI all ,
   I have some trouble ,
i need to receive the data from database , how can i use labview to check that the table is add a new row ?
i want to check number of the row in the table so that i can see wether the number of row in the table have changed.
i have tried to use shift register and event structure , but i fail .
is there any other method ? or example to do this ?
Thank you !!
Message 1 of 9
(5,241 Views)
Why does a shift register and event structure not work?
Here's how I would do it:
- Create a while loop, and add a shift register.
- Have an event structure, triggered by a value change in the table.
- Put your data in an 'array'.
- Initialize the shift register with the original array.
- Inside the event structure, use the 'array size' function the new array and the old array
- compare the values of the number of rows.
- if they are different, a row was added/deleted
Message Edited by Cory K on 03-20-2009 12:02 PM
Cory K
Message 2 of 9
(5,239 Views)
Dear Cory K  ,
      Thank for your help !
now , i can use SQL to know the size of my table
oh..sorry  , i still can;t understand , do u have some example ?
Message 3 of 9
(5,236 Views)
I made a simple example to show you how to implement this logic.
See if you can follow the attached VI.
Let me know if you have any more questions.
Cory K
Message 4 of 9
(5,197 Views)
Thank you
But i can't open it , as i don't have VI 8.5
do u have 8.2 or just pastle the image to me ?
Message 5 of 9
(5,185 Views)
Here you go. Also did a little modification to Cory K's code so that you can see the results more clearly.   🙂
Message Edited by ssingh1 on 03-21-2009 08:07 AM
Message Edited by ssingh1 on 03-21-2009 08:08 AM
Message 6 of 9
(5,143 Views)
Hehe ssingh1, he said he cant open 8.5 because he has 8.2, so you modified my code and attached it in 8.6Smiley Wink
Thanks though.
Anyway, I reattached the code in 8.2
Cory K
Message 7 of 9
(5,122 Views)
It's still in 8.5 😮
Your example is quite flawed (why local variables, why slice out colums to get the number of rows? Why no stop event? Why is there a timeout event? Why do we need a shift register?)
Here's a quick alternative.
Message Edited by altenbach on 03-21-2009 09:33 AM
Message 8 of 9
(5,116 Views)
I'm still in the phase of figuring out how to make a VI function properly.
Coding correctly and efficiently is an entirely different ballgame Smiley Very Happy
Cory K
Message 9 of 9
(5,084 Views)
