Detecting Objects via labview + vision assistant doesn't work
Hey guys, i need some help with my new labview project. I'm trying to detect some objects with my smartcamera. Therefore I created a labview program, which is using vision assistant for pattern matching. The problem is, that vision assistant doesn't get the latest Image that vision acquisition just created before. When I'm running the VI I only get a picture of my objects, but nothing gets detected because vision assistant doesn't get the picture... I tried to fix it for hours, but I just don't get the mistake. Maybe some of you have a better eye for that.
I attached the VI and the Vision assistant script.
Thank you.
(3,457 Views)
Hey best_brawler,
I can't run you programm, because I don't have a smartcam.
Can you tell me, which VI caused the error message in the screenshot? Is this eror caused by the Vision Acquisition Asistant or by the Visson Assistant?
Stephan
(3,368 Views)
