Detecting and applying a value change of a control in a cluster which is an element of a array (example VI attached)
Nathand,
I noticed while trying to implement the much simpler method you put together for me that I missed a 'constraint' in my original example format that I was attaching-  The cluster element in my actual project I'm working on does not have identical controls (in other words I have a string, a boolean, and several numerics in the cluster element).
This means I can't use the cluster to array (right?).  I just spent about 2.5hrs trying differet approaches, the only one that seems to work I'll attach here.
I'm curious if you know a much simpler way to fix this, and to get your thoughts on what I ended up with- do you see any flaws with it?
Thanks again!!!
-pat
Message 11 of 13
(512 Views)
There's still a simpler solution.  If you're already going to need a case structure to determine what type of data is in that cluster element, might as well simply unbundle the correct value out of the cluster inside the case structure intead of dealing with references, like this:
Message 12 of 13
(504 Views)
Nice!
...that's a lot simpler... lol
thanks a lot!
-pat
Message 13 of 13
(502 Views)
