Detecting compatibility of cRIO for DAQmx
I just know that some Compact RIO are compatible with DAQmx acquisition method. How could I distinguish between DAQmx compatible and incompatible Compact RIO programmatically? I just need a method like True/False just to allow me use different method for DAQmx compatible and incompatible Compact RIO. Thanks in advance.
(2,015 Views)
Accepted by topic author Ejun96
Just an idea:
You could query the installed software packages using the system configuration API VIs.
Regards, Jens
Kudos are welcome...
(1,969 Views)
Hi, Jens.
Thank you for the idea. But I didn't quite get on how to do that. Could you please elaborate or just simply attach a simple vi? Thank you
(1,933 Views)
Only 905x and 904x target series can have DAQmx support installed.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019PUNSA2
Software components installed on a specific target can be discovered with these VIs:
https://zone.ni.com/reference/en-XX/help/373107N-01/nisyscfg/software_subpalette/
(1,885 Views)
