Detecting rising edge of sync signal on NI 9205
Hi everyone,
I am acquiring a sync signal on the NI 9205 C series module on a CompactRio. The sync signal is a 375 mV square wave. The width is 15 ms. The sync signal is a 10 Hz signal.
The only difficulty is that the pulse signals are very noisy as seen in the attached images (twopulses.PNG zoomedinpulse.PNG). This is done with 100 us sampling time. I have attached a simplified image of the vi that I have so far which does a simple sampling of the signal (image.PNG).
How do you use Labview FPGA to detect the rising edge of the signal and to count the number of pulses?
(4,445 Views)
Hi Elliot,
I recommend taking a look at the Triggered_SW Gated Software - cRIO in the Example Finder under Toolkits and Modules >> FPGA >> CompactRIO >> FPGA Fundamentals >> Triggers and Watchdog. The description says "This VI samples an input when a rising edge is detected on the trigger line." Let me know if you have any further questions. Thanks!
Stephanie
(4,246 Views)
Here's how I did it for a motor tachometer using the PXI-7831R FPGA (see attachment).
(4,242 Views)
