Detection of peaks on a Log Scale.
Hi there
I am using a DAQ card to detect the amplitude voltage of a circuit. The output voltage is vairying and i want to detect the peaks. The chart has many peaks e.g. 20 peaks each one slightly smaller than the previous one.
I have tried using the Advanced Peak Detector PtByPt vi. but i am getting some strange results.
It seems to detect the first 4 or 5 peaks no problem but any subsequent peaks give strange results.
The peroid of the changing voltage is about 20 seconds.
Any suggestions???
Please see the attached file.
Capillod
(2,927 Views)
Hi Capillod
One thing to keep in mind is that the location that the peak detector outputs is a fractional index of the internally held data buffer so you will need to calculate from the fractional index the real location. The calculation is
PeakLocation = Fractionalindex – SampleLength + x
I’ve attached a demo that simulates a spectrum and passes it point by point into the Advanced Peak Detector PtByPt.vi this will allow you to simulate your system and fine tune the peak detection.
Good Luck
Kurt Friday
www.sciware.com.au
(2,916 Views)
Hi  May I have these downloaded files in version 7.0?
Many thanks in advance.
Clement
(2,873 Views)
Hi Clement
Sure, no problem.
Kurt Friday
www.sciware.com.au
(2,856 Views)
