Detection of port for LJ U3 LV in Labview
Hi all,
         Here i am using labjack U3 LV and i interfaced with labview, once if i close and open the labview(not only vi), the port is detecting, unless i remove and reconnect the USB everytime. I have attached a example code here for your reference, please take a look into it.
Thanks in advance for your favourable reply,
Dinesh
(2,244 Views)
You should be using the Close function after you have finished with the device. This will release the device for connection again.
Example close function attached.
(2,190 Views)
