Detection of the shift key down when application starts
I need to detect that the shift key is down when an LV executable application is first started.
I know this is possible in Windows because MS Access has this capability, but NI support has said it can't be done.
Does anyone know how to do this? I need to be able to do this in LV 5.0.1f1, but will accept a solution for later versions if it's not possible in 5.0. Also the platforms would be WIN95/98/2000/XT.
One thought was that maybe this information is written to the Windows registry and that it could be retrieved from there.
Thank you in advance.
PHILOG
(3,165 Views)
I have no idea how you would do it 5.0. LabVIEW 6.1 introduced the event structure and a quick test with the key repeat event shows that it's possible. I don't think that a key value is written to the registry but there is probably some windows api function that you could call. You might want to check the microsoft web site for info.
(3,163 Views)
I'm not sure if you can catch a key down event occurred before LabVIEW is launched.
Poll the shift key status might solve the problem. This can be done in lv5.0.
George Zou
http://gtoolbox.yeah.net
George Zou
(3,150 Views)
You can't catch a key down event. What I tried was holding down the shift key before I ran a VI, kept holding it, and got a key repeat event as soon as the VI started. Haven't tried it with an executable but I would think it would work the same.
(3,147 Views)
