Determine analog input task trigger status
I am writing a basic analog input function, which will be triggered via a start trigger sent by another instrument. Is there a way to programmatically deteremine if the Analog Input task has been triggered? I would like to have a Boolean indicator that shows "True" after the Analog Input task is triggered, but I couldn't find out how. Does anyone have a suggestion? Thanks!
(3,478 Views)
Is this a continuous acquisition?
I am not aware of a function querying the trigger state of a task. Nevertheless, i don't think this is necessary as you usually start reading right after starting the input task.
So in case a trigger is late, you will/should run in a time out error. Otherwise, you will get some data which is a clear indication that the task is running....
Norbert
Norbert
Expert: Geometry
(3,450 Views)
If you really want a green light you could always put in logic to turn on an led on the front panel if the error cluster coming from the read is not showing an error.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,423 Views)
