Determine if signal is changing?
Quick question:
I am acquiring a simple voltage signal from a pressure sensor.  And I am building a simple LabVIEW GUI for calibrating the measurement.
For the calibration, I am applying a knopwn pressure to the sensor.  And then I want to use LabVIEW to detect if the signal has stopped changing ... e.g., detect if it has settled to a steady-state voltage.
Any tips on a quick way to calculate this?
I considered trying to fit a line to the last 5-10 seconds of data and then calculate the slope of the line ... if the slope is not very close to zero, then the signal has not flattened out.
http://www.medicollector.com
(2,506 Views)
Use some of the statisics functions.
There is a distribution calculation function for an array.
If you detect that the distribution is small enough to be considered 'steady-state'  you can take the mean.
Ton
My LabVIEW Ideas
(2,490 Views)
